1 / 2
Suunto A-10 SH Compass
1/2
Suunto A-10
SH Compass
Suunto item: SS012055014
€0
Add to cart
The compass consist of a transparent plastic mainly rectangular base with a rounded edge against the hand and a circular dial assembly with a liquid damped compass needle. The compass does not have any light sources, is magnetic, unmounted, and suitable for field conditions.
Physical specifications
Product dimensions: 104x56x10 mm
Net weight: 30 g
Package dimensions: 73x22x180 mm
Gross weight: 72 g
Operational temperature range: -30˚C .. +60˚C . The compass will form a temporary vacuum bubble at about -20˚C.
Water proofness: Waterproof to all practical water depths as there is no cavity that can leak water in.
Storage temperature range: -30˚C .. +60˚C
Berry compliant: -
Compass baseplate specification
Baseplate: Three straight edges and one rounded side that fits the hand in a good way, transparent, made from impact and scratch resistant PMMA
Rulers and scales: cm and inch, with map distance helpers
Compass needle/card and protractor specifications
Protractor diameter: 48 mm
Primary direction scale: On top of rotating protractor alligned with outer edge, DEGREES scale 0-360° clockwise with 2° resolution and a number every 20°. Diameter: 45 mm.
Cardinal markings: N, E, S, W on protractor
Magnetic balancing: Southern hemisphere.
Needle design: Red for north and black for south. The center of the needle is transparent and the damping shape of the needle is also transparent. The hub of the needle features a NdFeB ring shaped magnet.
Needle length: 32 mm
Needle movement damping method: Non-freezing transparent liquid filled compass capsule.
Compass capsule: Hermetically sealed transparent PMMA capsule, diameter 35 mm.
Orienting arrow: Red and black colored, located at the bottom of the rotating capsule.
Declination corection: Fixed scale at the bottom of the rotating capsule going from 0 at the orienting arrow and extending 90° E and W. The declination correction has a two degrees resolution and is marked with a number every 20°.
Protractor index: White line on black background under protractor scale.
Luminescent features
Compass Needle: Not luminescent
Orienting arrow: Not luminescent
Protractor: Not luminescent
Protractor index: Not luminescent
Direction of travel: Not luminescent
Lanyard: 1 m red reflective lanyard with quick release
User guide
Paper with product: Yes
On line: Yes
USER GUIDE
Download
