Lensatic sighting clinometer in aluminium housing.
Suunto PM-5
/360 PC Clinometer
Suunto item: SS011096010
NSN code: 6675-17-054-1961, 6675-21-905-6892
Contact Us for Military Procurement
For defence procurement, tender participation, or inquiries about custom compass development:
Our dedicated defence sales team is ready to assist with your requirements. You can also follow us via Facebook and Instagram.
Physical specifications
Product dimensions:
52x77x15 mm
Net weight:
94 g
Package dimensions:
92x42x131 mm
Gross weight:
217 g
Operational temperature range:
-30˚C .. +60˚C
Water proofness:
The clinometer capsule is water proof to all practical depths. The cavity around the clinometer capsule will get water filled. Remove the ocular to drain. Rinsing both the inside of the instrument and the ocular to remove salt is highly recommended to the keep the reading clear.
Storage temperature range:
-30˚C .. +60˚C
Berry compliant:
Clinometer
Clinometer feature:
A low friction weighted rotating card with inclination scale is located in a liquid filled capsule. The side of the card has an inclination scale that is read through an ocular. An index line is visible in front of the scale.
Clinometer scale:
Compass card with a coarse degrees ±90˚scale with a 5˚ resolution and a nummber every 10˚. The outer side of the compass card has two fine scales; one with degrees ±90˚scale with 1˚ resolution and a number every 10˚ and one slope ±150% scale with variable resolution 1-2% depending on slope and number every 10%.
Sighting Tools
Lensatic:
Ocular that is looked through with one eye to se the scale on the the side of the clinometer card while the other eye sees the target.
Lanyard:
1 m red reflective lanyard
User guide
Paper with product:
Yes
On line:
Yes
- Email: defence@suunto.com
- Phone: +358 9 875 870
