1 / 2
Suunto SK-8/Orca Capsule SH
1/2
Suunto SK-8
/Orca Capsule SH
Suunto item: SS021121000
€0
Add to cart
Compass capsule for building into dive or parachute navi boards or to use as spare capsule for Suunto SK-7 and SK-8 dive compasses.
Physical specifications
Produet dimenslons: 55x55x30 mm
Net welght: 40g
Package dimensions: 80x80x30 mm
Gross weight: 43g
Operational temperature range: -30˚C .. +60˚C.
Water proofness: Waterproof to all practical water depths as there is no cavity that can leak water in.
Storage temperature range: -30˚C .. +60˚C
Berry compliant: Yes, no fiber material in the product
Compass needle/card and protractor specifications
Protractor diameter: 59mm
Primary direction scale: The compass card has a DEGREES 0-360 scale along the outside for direct reading from the side, with 5˚ resolution and a number every 30˚.
Cardinal markings: N, W, E on compass card
Magnetic balancing: Southern hemisphere.
Needle design: Compass card with N, E and W cardinal directions on top. The outer side of the compass card has a DEGREES 0-360˚ scale with 5˚ resolution and a number every 30˚.
Needle length: 41 mm card
Needle movement damping method: Non-freezing transparent liquid filled compass capsule with the absence of bubbles in the operating temperature range at sea level.
Compass capsule: Hermetically sealed transparent PMMA capsule, diameter 49 mm.
Luminescent features
Luminescent material: SrAl2O4
Compass card: Fully luminescent with black print
Protractor index: Line in front of luminescent compass card
Direction of travel: Line in front of luminescent compass card
USER GUIDE
Download
